Where Can I Buy A Chain Adjustment Tool - 250x
5 reading
9.7K views 13 replies 10 participants last post by  oldskool83
#1 ·
Where can I get the tool (don't know the exact name of it) that you use to adjust the bearing carrier for a 250x? I know you can use an allen wrench or a large screwdriver, but the aluminum is already been damaged somewhat so I would like to find the correct tool for it. If anyone knows where I can get one or has a link I would greatly appreciate it!
Thanks
#3 ·
me either...if it's anything like all the chain drives i've seen...some of them have allen screws that tighten down around the carrier..and then you just push or pull the carrier. some have a long bolt with a washer type of holder that goes around a carrier bolt holder spot..which you use a 12 mm deep socket to loosen or tighten to move the carrier...other than that..i have no idea.
#9 ·
Yeah, that looks like a spanner wrench used for adjusting the shocks, unless they make a spanner wrench to turn the bearing carrier, too.
#12 ·
Yeah, it's just a basic spanner wrench, so if it fits it will work.
#13 ·
When I had my 300ex I cracked the carrier by taping it with a hammer. I know... It was a stupid thing to do. I found some spaner wrenches at home chepo that work well for adjusting the carrier. The only problem I found with them is if you over tighten the chain the spanner wrench will only work in one direction. So I just use a oil filer wrench or a scrap pice of pine and a mallet. Kinda ******* but has worked well so far.
#14 ·
with the billet aftermarket carried they older style that had the hole you need a round price of metal, they use to come with them but if you buy them from ebay they wont so i use an allenwrench.
for the new style billet carriers they are kinda slotted like oem but you put in a 1/4" ratched extention and it works perfect. i honestly dont know why they cant machine the carrier like a locking nut so we could use a wrench!
