aight, the rear brakes dont work, dont care to fix them. i
want to do away with the hole assemble.
pretty much with the assemble off it leaves the axle going into the tube across the rear end but there is a gap so it has some play and im pretty sure that will mess up the bearing on the gear side of it. also i dont know if the gear side is sealed so if water got into the tube it might be able to get into the rear diff. someone correct me on that if you could.
pretty much the brake assemble holds the axle in place. i have thought about cutting that to the size of the tube and still retaining the stock bolts to the axle but then im going to run into a sealing issue on the other side of that.
it would be cool if somebody made a bearing to fit that gap and just do away with the whole assemble.
what do you guys think??
