The Dial-A-Jet system allows you to adjust your fuel flow without taking the carb apart or even touching it. When properly installed, the Dial-A-Jet draws extra fuel into the intake system. Depending on the engine load, the Dial-A-Jet automatically adjusts the amount of extra fuel that is needed. The extra fuel is pre-mixed to an atomized state with incoming air before it reaches the carburetor, similar to a fuel injection nozzle. Also, for severe altitude or temperature changes, you can stop the vehicle and make a dial adjustment of about four different mainjet sizes to compensate for the different conditions. To achieve this, five different sized holes on the dial help additional fuel that is needed in the carb.
It is very simple to install and the instruction are easy to follow. Depending on what you have done to your quad you might need to change your mainjet one or two sizes. Mine is still stock for now so I went from the stock 148 to a 142 mainjet. Usually about two sizes leaner then what your mods would call for.
You will also need to make one hole in the rubber air-boot between the carb and airbox. On the EX you remove the stock drain screw from the float bowl and replaced it with a hollow fuel delivery tube supplied with the kit. You will also need to modify your choke lever by shortening it or as I did removing it and lightly heating and bending it. The choke level is not mentioned in the instructions, but easy to figure out what to do with it. If I knew about this before hand I would have had them add a threaded float bowl fitting, which doesn't come in the kit for the EX. This fitting you'd need to drill a hole in the float bowl drain nut on the bottom of the carb and thread it for the fitting.
This setup will only affects the main jet and will not effect the idle. There’s a small increase in mid and top-end power, but it’s only about two horsepower. An average rider might not even notice a thing. This might be different depending on what mods you have.
The main reason I got it was cuz I run elevations from 800 to about 7000 ft and year round. It now takes me about 5 seconds to rejet my carb.
You will also need to get a Snorkel for it and might want to get a One Way Check Vavle and a deeper Float Bowl Nut.
Hope this helps.
