Badlands 2500 wireless remote winch, anyone hardwired in a switch?
1 reading
35K views 11 replies 8 participants last post by  damfool
#1 ·
Look like I can get a Badlands 2500 winch for around $50, with the wireless remote. This winch is only going to be used by an old lady every other Sunday so limited action.....yes I know their are better winches out there cant beat the price.
Has anyone successfully wired in a standard up/down switches for this winch? One would think wouldn't be to terrible difficult. Don't like the 6 sec minimum action from the wireless remote. If anyone has, could you recommend a place to get the hardwire switch and a universal mounting plate.
It will be going on a 2007 Ranger.
#4 ·
don't think a LOT of us here have badlands winches so??
but most other winches have in/out switches and all work fine with what the makers provide
I have a supwerwinch and have mine mounted near my left thumb so I can in/out while driving for when plowing with my hands on the grips still
I have to think all switches for winches would work here, get one from Badlands, or supwerwinch or warn, or mile marker or???
they sell replacement one's and come with all mounting hardware MOST times
#5 ·
I have 2 Badlands, 1 came with the wireless. About $45 will get you a set of relays [solenoid], switch and wires from EBAY. Even comes with the wiring diagram. I tossed everything but the winch it's self. After looking at many brand names - they all came with the same motor/winch assembly
#6 ·
I have done it using a KFI handlebar switch in addition to the wireless setup. Inside the black box is the contactor and the wireless receiver. You just need to wire your rocker switch in parallel with the wireless receiver's outputs on the contactor's coil pins using piggyback terminals.
#7 ·
Had issue last week. Quad worked well all winter. Winch worked great with my plow. When to lower my blade to take off for the winter, quad dead. Battery drained. Thinking the remote receiver must always be on and will drain the battery after awhile. Disconnected winch, charged battery, good to go. Will be adding in a kill switch to winch to avoid dead battery in the future.
If installing this winch highly suggest installing a kill switch.
#8 ·
The wireless radio is fed with a red wire that is tied to the power feed inside the contactor box. What I did was feed that red wire from an ignition feed from a relay that I added. That same ignition feed also feeds my lights that I added as well as the handle bar winch switch. That way when the key is off everything is dead.
