Hondarubicon, I just went through this also and nearly pulled my hair put trying to figure out why the new sensor I had just replaced went bad so quick and it could be something as simple as the plug not getting plugged in very tight when you replaced it and some new riding time vibrated it loose which was my situation. Check the simple things first because if the codes you are reading indeed tell you that you have a bad sensor then that should be your problem and just as Kentco said you do have to have a good charged battery. Your manual will run you through all of the steps which I am sure you know you can get from this forum. Good luck.
