I decided to pull the jug off my '06 400 AT while I had the head off. Previous owner (a friend) had put a new set of rings in and lightly honed the cylinder in an effort to get it to stop smoking. Turned out the smoking was caused by a bent exhaust valve and cracked valve guide. It has less than 2 hrs on it since the new rings.
Cylinder to piston clearance is within spec (.003"), cylinder is not out of round, but the top ring end gap is .08" and the 2nd ring end gap is .115". They don't appear to have been filed on, but the difference in end gap between the two rings is greater than the maximum end gap spec.
I don't know what to think. Should I just try another new set of rings? I would think the end gaps are way too large to put it back together this way.
Any input would be appreciated.
Thanks,
Phillip
Thanks,
Phillip
