Does the display still light up and the hourmeter still work? If so, first try cleaning the connector like Mudmat said. If that doesn't work, the speed sensor is probably bad. I had to replace the one on mine. If the speedometer doesn't light up and the hourmeter doesn't work, then it's not the speed sensor because both will still work when the speed sensor goes out.
