Hello all, I know this another post about bleeding problems but I can't figure this thing out on my own apparently. I've read almost all of the other responses and I've learned a lot of useful information, yet I still have no brakes and have only become more agitated with the situation. To start off I have considerable knowledge on this issue with cars and motorcycles but never with atv and I'm sure I'm being impatient with it. I'll begin with a brief background of the problem: I have a 96 fourtrax 300 4x4, front brakes worked fine for the longest but in the last year the handle began loosing it's bite. I started at the bottom, adjusting the shoes and checking for leaks at the cylinders, banjo bolts and just about anywhere else fluid could leak....no leaks...shoes adjusted correctly but still no pressure at the handle...I finally ordered a rebuild kit and installed it....I'm pretty confident it's correctly assembled I mean there are only 5 parts anyway....tried to bleed the normal way just by squeezing the handle to build pressure and quickly loosening the bleeder screw......no help.....I went and got the vacuum bleeder and ran a quart throughout the system..... No leaks. All fluid is clean and flows through with no problems but still not even a slight bit of pressure at the handle.....I was browsing through the forum and stumbled upon the vise grip trick to buil pressure close to the mc.....when I do it on my wheeler no pressure build up at all, but when I walk over to my girlfriends wheeler which is the same model but a 97, hers becomes rock hard (makes sense cause her front brakes still work but are also beginning to fade) so I'm left thinking that either the kit is defective or the mc is messed up on the inside where the other rubber component is, that has the little x opening....basically I want to know is this a sign that the mc is useless or is there something else that I can try to get these brakes going....sorry about the novel....thanks in advance Andrew K
