Just got a new air Filter to day and when i was installing it said i need to oil it. it is a twin air air filter. can i run it as a dry filter or do i have to use oil with it?
Here is What i got Link
In a zip lock bagso do i oil the inside only?
Don't know the answer, but any foam filter oil should work. Twin Air sells their own.if so what is the best oil to use for it?
Never heard of that.i read that you should not let it sit so do i need to remove the air filter when i don't ride my atv?
Potential to suck dust into your quad's carb and cause it to stop running correctly?Question: what would happen if i did not oil it?
In dusty conditions, after every ride. Obviously this doesn't mean everytime you pull it out into your yard to play around, but after long trail rides at the end of the day.and how often do i need to reoil it?
