Hey guys,
Brand new to the forums, but I've had a lingering problem with my atv.
Basically, I got this quad off a friend when he blew the motor on it. I bought a used motor and swapped it right in. I did a leak down test and adjusted the valves. Don't know the hours on it. Figured it would be a cool project.
Got it running. It idles great, but would bog down and almost die when I open up the throttle. Does ok when you lightly push in the throttle, but when you slam it down for power, it Boggs out, usually dies if I leave it wide open.
Here's what I've tried;
Cleaned the carburetor. Took it completely apart and soaked everything in carb cleaner bucket for about 10 hours (while I was at work) then put it back together, and it idled better, but had the same problem.
Then I bought a brand new carburetor for it. Just wanted to cut out the tinkering and was frustrated. Installed it, and still have the same problem. Starts right up. Idles great, let it get to operating temperature, then push the throttle down, its spits and sputters till it dies!!
I'm really stuck here guys. I've come to the forums before and found some great tips without even posting..I'm stumped! Any help would be appreciated.
