So just replaced a crankcase cover on the motor, honed the cylinder and put new rings on it. Adjusted the valves to .006 and now I have a tapping noise mostly after when you rev it up. It's not really if any ticky or knocky on idle or if you hold the throttle 1/2 but when you let off it makes the noise. If checked things and made sure my valves where set and everything was tight but havent found nothing. My cam chain was pretty hard to get on and seemed pretty tight so I dont think that's it. Noise sounds like it's coming from the top end. Any ideas would help. Thank you!
