Help please 350 Rancher noise after top end rebuild
7.3K views 4 replies 3 participants last post by  TheNatural
#1 ·
what noise is this , cam chain or just bad gas any help would be appreciated thank you
#4 ·
i drained the old gas and put fresh gas in it .it helped a little but noise is still there i am guessing it is cam chain , i checked the push rods and marked them when i put the new head on , rolled them across a flat surface , and checked for up and down play on the piston rod but i didnt go past the top end thinking that was all that was wrong with it , i rebuilt it for a friend , it had been sitting for a couple years with a seized piston
#5 ·
Check the valve seats. My 2006 was making a noise like that, apparently it was one of the valve seats that had separated from the head and was rattling around. I didn't figure it out until the valve seat had shattered and taken out the piston. Apparently it's a somewhat common issue.
