300ex dies out (video)
4.7K views 12 replies 6 participants last post by  Nuke
two and a half is too much. i did two and it would barely start on me, i'd have to put one choke for it to just barely start but turn off once i hit the throttle, which means it needed more air. from what i determined it is best between one and half and one and three fourths
no with choke on it needs more fuel. pull the plug and see what color it is if its black then too rich if white too lean so after that you can determine what it is or take the air box lid off and test your theory if it runs better with it off then its too rich and i highly doubt it is it sounded way lean. if it runs worse then its lean do as yamahasucks says and try out what did you do to the carb? and why?
