I have 2 86s—you can find these used and occasionally NOS.Hi Sam, I think I've read just about everything pertaining to it here in the forum. It's an 86. Honda shows part # 38710-HA7-671 as fitting 86-87, and #38710-HA7-651 as fitting 88-89. The difference being the later model incorporates an overload to cut fan power if the fan motor seizes. They are wired identically on all models. Either should work. Unless I'm missing something.
Hmm have you done a resistance check on your oil sensor? Does your oil light come on momentarily at “ignition on” and then go out?On mine the warning light comes on and off at will (usually on) even when cold, and the fan starts and stops erratically for no reason as well. Jumping sensor wires has no affect on anything. All wiring is perfect. I will try your oven fix. I have nothing to lose. There is only one on ebay now, and it doesn't inspire confidence. I figure more will turn up in time, but in the meantime I thought I'd check here. Thanks Goober.
