I am working on a 2003 TRX 350 ES that has a very loose "A" Arm, Lower, and busted tie rod end, inner.
I replaced the tie rod end and bought the new "A" arm. The Mounting bolts are severely worn so they will be replaced. The primary problem now is the frame mount holes are badly worn. Any fix besides replacing the frame?
I considered making a bushing/washer and trying to have it TIG welded to the frame. Welding and machine shop time could run into several hundred dollars, but it might be my only option at this point. I realize alignment could still be a problem, but there is quite a bit adjustment for TOE.
Any help is appreciated. Arctic Putter
