I have a 2012 Rancher 420 (p/s, i.r.s., e.s. so the FPA?) that won't shift into reverse properly. I've already ruled out the cable and downshift button on the bars as it will upshift into drive and then downshift into neutral. I can take the manual override wrench, push reverse button and pull the handbrake while pulling up and the wrench and make it go to reverse. When I do this however the indicator flashes 2 long times and 3 short times. The machine stays in reverse but won't come out until shut off. Any ideas on what could be the problem or what the code its telling me is? I'm new to electric shift fourwheelers so I'm at a bit of a loss with this...
