Can anybody tell me the size wire used on a 2016 Foreman 12v accessorie plug?
Hi: #18 is good for 10amps --- #16 is good for 20 amps -- so use #16.
Reactions: _Wilson_
just out of curiosity, what are you planning to use the plug for? some applications may cause more problems than it is worth.
I want to tap into the exsisting wire with a Posi-Tap, I can access it without taking anything apart but want to know the size of the wire to get the right posi-tap.
Hi: That wire is fused with a 20 amp fuse --so use a #16 wire
Reactions: SamUK and _Wilson_
I want to know the size of the stock wires, not what to use. Thanks anyway
Hi: Your 2016 Foreman accessory socket 12 volts -- on your bike the accessory socket is fused with 20 amp fuse (ACC F) so the wire on your bike has to be a 16 gauge wire to carry 20 amps through it to the socket.
Reactions: _Wilson_ and SamUK
