1 - 20 of 23 Posts
2017 Honda Foreman Rubicon 500 DCT/PS
So im planning on buying a winch. Obviously anyone that rides off-road needs one. But I plan on getting the Warn brand winch. Thing is whats the difference between the VANTAGE and the PROVANTAGE? Also more than likely gonna get the synthetic rope and not the wire. Also what pound should I get? Bigger the better?
not sure what the difference between the vantage and pro vantage is ?. I have bought 2 warn pro vantage 2500s, with a K.F.I. mounting plate, and a roller fair lead. if your going to go with the rope ? ( which I love ! ), make sure to get a roller fair lead, NOT THE HAWSE FAIR LEAD !. the warn pro vantage 2500s is more than enough to handle what you need. instead of buying anything larger ?, buy a warn accessory kit, you get a d-shackle, tree straps, and a snatch block. a snatch block will double the pulling power of that 2500 lb winch, comes in very handy.
Reactions: alexhill870
I am a fan of Spectrum ( synthetic rope ) , one thing I learned is if your winch comes with wire rope and you are going to change it over to synthetic then don't buy that crap from Harbor Freight , go to a marine supply store , that cheap stuff is no where near the quality
You can use an aluminium Hawse or a roller fairlead with a wire rope or a synthetic rope, fact, tried and tested.
Just don't use a synthetic rope on a USED roller or hawse, you'll have a scrap rope within seconds.
I find when you get into steeper angles with the hawse fairleads it will start chewing up the synthetic cable. I've winched my Renegade onto my truck a few times and you notice it then.
anytime you use a hawse fair lead on rope ?, it causes friction, friction is heat, heat makes the rope break. use a roller fair lead, problem solved.
I use a fairlead mainly because my winch gets used every time I go out, like the guys above have said it is easier on the winch rope. I'd use either though, a thick Hawse is essential though to dissipate the heat generated by friction.
back in the day when winches had nothing but cable ?, all you seen was roller fair leads. fast forward to today, we have rope. when I gave it a lot of thought, I decided to go with the roller fair lead to make it easier on the rope. my rope still works and looks like it did the day I installed it
Yep, I remember the times when it was only roller fairleads available, used to cost a fortune too if I remember rightly. I must admit, synthetic ropes are a fantastic bit of kit, intend to wrap mine around my carrier once it's spooled out. I wouldn't be scratching my carrier with a wire rope I tell you that lol.
Provantage is the one you want. Warranty: Limited lifetime, 3 year electrical (North America). The Vantage is Warranty: 5 year mechanical, 1 year electrical (North America).
also, if your looking for a GREAT deal on a winch kit, have a look at the one at tractor supply company stores, its everything the Warn has(I have a warn one)
and its at a fraction of the cost
ALL war things come with added prices due to there Name, NOT saying there bad in any way, just your buying a name at times more than some things!
and i'll bet you a dime to a dollar, a warn will out last that tractor supply winch in the long run !..lol.
Shade I am NOT talking about the TSC WINCHES< LOL, just there winch KITS
the kit has everything the Warns do, snatch blocks(heavier rated too, or then the snatch block that came in mine from WARN) c clevis, gloves , and like, for HALF the price of the warn, and decent bag too boot(my warn bag seen better days) , again I have the Warn atv winch kit, bought mine back in 1999, and seen what is in the TSC kit, its the same like things, hard to mess up snatch block or a clevis here LOL
SO??
OH< the tree saver from WARN is a an extra ft and half longer or so??
SORRY LOL
meh, no worries bro. I try to stick with what works for me, and I guess every one has their brands they like ?, sooooo..to each their own..right ? :).
Is ice a factor when the rope is continually frozen/thawed ....... expanded/contracted ....... heated by friction in a hawse fairlead ?
This may not be a factor for you southern folks ...... up here, it is a factor.
Rope may be the greatest thing since 'sliced bread' ........ but, it isn't used in the forest industry at all - where winches are used everywhere ....
I'll stick with the 'tried & true' wire in a quality roller fairlead ...
Harbor freight has a big sale on winches this weekend on the Badlands 2500 for super cheap , you can get 4 or 5 of them for the price on one Warn , then you can put 2 in the front and 2 in the rear , keep one for a spare when the other 4 burn out
yeah, I am sure weather, such as ice, would effect rope on winches. some things calls for cable, and some call for rope. if your pulling heavy/bulky loads, such as trees ?, then yeah, cable on a roller fair lead would be best. but, if your only using your winch to pull the atv out ?, then rope will work great, but as you said, weather on it would not help it any better.
1 - 20 of 23 Posts
