1 - 10 of 10 Posts
hello i have a 87trx250r i bought from sombody and will not idle i manage to get it to kick cold on second kick but when let off throttle or push choke in shuts off. it runs 50-1 amsoil oil with 93 octane and has vforce delta 3 reeds thats about all i can tell ya. it wants to bog at 1/4 throttle but after that it screams some info would greatly appriciated thank you.
Try cleaning your carb.
well i cleaned it out but also noticed that the c ring on needle was all the way at the bottom setting. i put it in the center slot which should be stock right? and was is any of the screws on the side of carb adjustment screws/
there should be a adjusting idle screw on the bottom of the carb..if not..then it's on the side..it will have a spring on it..as for the c-clip..yes..center is stock..the reason they put 5 groves in them is..for when your jet needle wears the seat..or your needle jet wears..you can lower or raise it to allow better fuel mixture.
The clip should be on the 3rd groove from the top. This shows the air screw adjustment.
Uploaded with ImageShack.us
Discussion Starter · #9 ·
i can adjust the idle with the nob on top of the choke but it will idle with choke up but when i push choke in it wants to shut off unless in giving it gas i have it turned out 2 1/2 turns.
1 - 10 of 10 Posts
