and your not going to notice that much difference with just a jetting. trx300fw's are NOT speed demons..never have, never will be.I have a 94 TRX300FW and curious about the comment you made about re jetting and the 88 cam. I did a rebuild on mine and installed a different cam out of an 85 250 3 wheeler I believe, Fishfiles posted on my build thread and gave some advice on it, so I'd have to go back and look to see exactly what it was. My question is : what cam are you referring to, what exactly does it do and can you elaborate on the jetting? Mine had a crappy China Ebay carb on it and I couldn't get it to run worth a hoot so I found an old factory one and rebuilt it with a Shindy kit and it made all the difference in the world! If I can get more power re jetting without it causing overheating issues or any other problems, I'd definitely like to do it. I appreciate the info Cool.
The truth is lol, is that even though i'm prepared to put the '88 300 cam in mine I still haven't. (it comes from a 1988 fourtrax 300). The cam will add high-end power and a little more power output overall. Some say they lost low end doing it, some say it's just better. I need to find out myself. BUT I installed this white bros exhaust and rejetted with a dynojet kit using the 124 main. I advise you do the same. You CAN get more power rejetting. Infact, the difference it made on mine was more than just a tiny bit, (contrary to the naysayers on here who claim to know all and seem to be doubtful of little things like this.) It does give you more power and make it snappier. After changing the jet to what dynojet says, I found that the air/fuel mixture screw position ran too rich, so if you mess with that and get it right you will get a boost. This is what I have been doing the past 3 days and I am much happier with it. Find out the truth yourself. The jet size and air/fuel mixture is key.I have a 94 TRX300FW and curious about the comment you made about re jetting and the 88 cam. I did a rebuild on mine and installed a different cam out of an 85 250 3 wheeler I believe, Fishfiles posted on my build thread and gave some advice on it, so I'd have to go back and look to see exactly what it was. My question is : what cam are you referring to, what exactly does it do and can you elaborate on the jetting? Mine had a crappy China Ebay carb on it and I couldn't get it to run worth a hoot so I found an old factory one and rebuilt it with a Shindy kit and it made all the difference in the world! If I can get more power re jetting without it causing overheating issues or any other problems, I'd definitely like to do it. I appreciate the info Cool.
Who knows what would happen to his? Mine made a difference. No, you probably won't get anything if all you do is rejet without adjusting and getting everything dialed in. I decided to find out myself after putting it off because I was told none of this would do anything. And I guess I learned a lesson. I know whats best for my bike and i'll think for myself from now on about it.and your not going to notice that much difference with just a jetting. trx300fw's are NOT speed demons..never have, never will be.I have a 94 TRX300FW and curious about the comment you made about re jetting and the 88 cam. I did a rebuild on mine and installed a different cam out of an 85 250 3 wheeler I believe, Fishfiles posted on my build thread and gave some advice on it, so I'd have to go back and look to see exactly what it was. My question is : what cam are you referring to, what exactly does it do and can you elaborate on the jetting? Mine had a crappy China Ebay carb on it and I couldn't get it to run worth a hoot so I found an old factory one and rebuilt it with a Shindy kit and it made all the difference in the world! If I can get more power re jetting without it causing overheating issues or any other problems, I'd definitely like to do it. I appreciate the info Cool.
Here is the one and only thing your missing in the argument. The reason honda did what they did is because it was safe and met emissions standards. Every engine is entirely different. Some may have a good exhaust design right out of the box. Alot of times on car engines and truck engine the only way to flow exhaust better is long tube headers. Shorty headers are 100% the same flow as stock. But this is getting alittle heated fellas. Lets keep the 3rd member measuring to a minumum please.:grinI realize that a better breathing engine will produce more power. My point is, simply dumping more fuel and adding more flow to the exhaust doesn't change the fact that the rest of the engine hasn't likewise been modified to realize the benefits of those components.
I put a $500 Borla stainless header on a Jeep 258. Made very little difference. Yeah the exhaust has the capacity to flow better, but the stock head on a 258 doesn't allow the benefits of a higher flowing exhaust. If you want power out of a 258 you have to swap to the high output head from the later 4.0 inline 6. Otherwise the design of the head keeps any bolt-ons from getting you any real power increase.
You're dealing with a single cylinder Honda engine with a stock head? Perhaps it wasn't tuned right before you started, but slapping a muffler and a jet kit on a stock Honda motor isn't going to do much, if anything except make your wallet lighter.
But I'm sure ya'll know better than the Honda engineers who mated up a particular exhaust, head, carb, etc right?
