I bought it used, think it's a 2007 or 2009 Foreman 500, can't recall exact year. I've had it two years, no idea how long previous owner owned this battery. I have had it at my land, it has had no battery tender on it and, in fact, I have never charged the battery, it has cranked just fine. I went to start and it just clicks. The connection seems secure. I tried to jump it, no luck. Not sure I got a good connection, there's not much to hold onto! It has enough juice, the screen lights up but now, after several tries, it doesn't show which gear it is in, so, I maybe it just barely has enough juice to run part of the screen? Anyway, it clicks so maybe it's just a bad battery? Walmart and Tractor Supply are handy, if I need to go to a dealer, that's a bit more drive than I'd like to do but I will if I need to. Where's a good place to buy? BTW, I couldn't even get one of the bolts out! I got one out with a 10mm socket, it seemed to fit. I am going to take some spray for battery gunk and see if that doesn't clean it up a bit more so it will take a socket for the other one. They should be same size bolt? Does it just lift out or is there some trick to removing the battery? TIA!
