1 - 2 of 2 Posts
I just bought this 2001 foreman 450 and can not find where to add transmission fluid. Also, the driveshafts are enclosed so how do I grease them? Thanks for your help
The 450 Foreman doesn't use transmission fluid. The crankcase just uses oil. Just feel it with oil up to the full mark on the dipstick. Make sure you use an oil designed for wet clutches or your clutch will go out.
As for the shafts, you have to take the boots off to repack the joints. I wouldn't worry about it, unless the boots have holes and are leaking. If they have holes, you'll need to replace the boot or the joints won't last long.
1 - 2 of 2 Posts
