looking to get the ipt ss212 michined 12" with ipt mud lites xlt f 26"x10"x12' R 26"x12"x12" anyone rnning this setup or close to it with pic's ? would like to see how it sits and rides thanks
You are absolutely correct. A taller tire/wheel combination changes your gear ratio. It is pretty difficult to find larger tires and after market wheels that weigh less than the factory sets do. If you go to a radial design you will add more weight. It is really up to the owner of the quad as to what he or she wants. I have had experience with issues caused by going too big in the tire and wheel department and was just passing on the information. With 27" tires on a 420 Rancher you WILL see a pretty substantial loss in power the first time you drop off into a large mud pit. I will add, the larger/heavier wheel tire combination can cause added stress on the drive train, clutches and etc.there are two things that play into that .one being weight, the other is height which causes loss of gearing, weight is the main concern.weight is what brakes things. not the fact that there is added height.the power loss I have obseved it not that great. the tire wheel combo that I have are around 30 lbs per tire wheel combo.which is at least 3 to 4 lbs less than mud lights on the same rims. I have had the ill fate of braking an axle due to a heavy a tire/ wheel combo. the combo was XTR with 14" rims. you just have to choose a tire wheel combo with less rolling resistance. But unless you spend a lot of time in the deep mud as most do down here than go with a milder tire.
Yeah we have to have pics. around here we have no imagination....lolwell i order my wheels and tires going with itp ss212 in black with itp mud lite xl 25x8-12 on front and 25x10-12 on rear went with 25"
becouse im not going to be going in deep stuff just trails,hunting and work some lil mud holes on trails ill post pic soon!
