I have a couple of questions, When I wheelie it I start in first then when im at a balance point it will shift to second although its a little jerky,will this hurt the four wheeler at all ?
2nd question is does anyone know where the oil pickup is,or if ill starve the engine of oil if i do long wheelies?
The last question is sometimes When i come back down or stand it straight up it will almost seem to switch in neutral or engage the clutch for a second,is that something to be worried about
I don’t think they were designed to “wheelie“ in the base case. They do have a flip sensor which may be causing you issues when wheeling.
2020 520 rubicon foot shift
I dont wheelie much but guys on youtube do long water wheelies non stop with ranchers without issue other than the flip/tip over sensor, you can disable it if you want.
I have no idea what would cause the clutch to engage for a second when you stand it up or set it down unless the tip over sensor does something to the transmission on the dct's too.
