I have a '97 TRX300. I'm in the process of trying to get to the drum brake, and the service manual says to remove the wheel hub.
I have removed the cotter pin, and I'm not sure what I'm supposed to remove next. There is a large nut, approx 1" that apparently needs to be removed from the end of the axel.
I don't have a socket that big, but I have tried using a pipe wrench, and a large cresent wrench, but can't get it to budge, even using a hammer.
The cresent wants to round the edges, and the pipe wrench is also damaging the nut.
Am I doing something wrong? Is there something else in addition to the cotter pin that I need to remove before I attempt to remove that nut?
I'm afraid to bang on the wrenches any more than I have for fear of destroying the nut. The only other thing I can think of is buying a socket big enough to fit the nut.
The problem is made worse by the fact that the sides of the nut are pretty narrow, probably less than 1/2 inch wide.
Any suggestions?
Thanks,
Greg
Any suggestions?
Thanks,
Greg
