1 - 9 of 9 Posts
my rims are 10x5 in the front and 9x9 in the rear, tires are 22x7 in the front and 20x10in the rear. i want to get hiper beadlock rims, 10x5 in the front but with a 20x6 tire and for the rear 8x8 rims with either a 18x10 or 18x11 rear tire but im not sure what size to pick. would this be a good setup or should i stay with the same size rims both front and rear and still go with the smaller tire in the front and rear??
i dont race mx or have a specific style of riding or anything i really ride all over the place and ever now and then i go out on the track and i have jumps set up everywhere........really im tryn to turn my atv into a mix of trail and mx, idk if thats a dumb idea or not i really just want to rebuild the atv to be good all around
I have several different sets of tire/rims.
My trail rig is....
22x7 Razr front
20x11 ITP mudlites or 20x11 Razr for the rear
For the track........
20x6 ITP mxr6 Front
18x8 ITP mxr6 rear
All on factory rims.
I rarely ride the track. So the trail rig stays on more.
tire width
im looking to buy new tires but i saw a few different choicesin width and dont know what width to choose. can someone explain the different widths or let me know whats the best to go with? i am wanting to put 20s in the front and 18s in the rear
That is a MX setup, if you do any trail riding you will lose a bit of ground clearance. Go as wide as you can get, the wider the more stable
You think 20x6 tire on a 10x5 rim for the front and 18x10 tire in the rear would be fine? I'm also not sure if I should use a 9x8 or an 8x8 rim for the rear. I'm wanting hiper beadlocks front and rear with itp holeshot tires....your thoughts....what psi would u run
Most of the MX guys go with an 8x8 setup. 18x10 would be fine. I'm a desert guy so I don't know much about the MX setup but that seems right for the front.
1 - 9 of 9 Posts
