I'd say you are right, because to bypass the clutch switch you would need to have the wires wired together, not cut.AHHHHHHH I bet someone had a kill switch wired into it. My buddy wired his 400EX in up there.
If they are wired together in a wire nut, then someone has bypassed the clutch switch. The clutch switch probably went bad.ok one is green and the other is yellow with green stripe and they are both inside a wire nt and taped
The diagram shows it running through the clutch switch, but the clutch switch probably went bad and someone bypassed it.So i should just leave them be the diagram shows it not hooked to anything right?
The clutch switch just lets you start the ATV in gear by pulling in the clutch. When it goes bad, you can't pull in the clutch and start it in gear, so they have bypassed it. If someone hadn't bypassed it, then you would have to put it in neutral to start it or replace the clutch switch, either one.ok thanks what does the clutch switch do?
