1 - 13 of 13 Posts
I have never compared weights before , I have some ITP Mudlites and Swamplites , they are light , for general riding the Mudlites do very well for my type of soil conditions , the Swamplites are a little more aggressive
4 ply kenda bear claws would be a worthy mention. As for ‘the lightest’, you’d have to do a comparison search or get in touch with a sales representative I suppose.
ITP mudlites AT's are 6-ply rated, not heavy. I do not know their weight ?. but I know they are not heavy !.
What are the lightest 25” tires
Since you have the Rancher 400AT, you may want to consider putting 12" rear rims on it to give yourself a wider choice of tires.
Also, stock '01-'14 Rubicon rims are 12", the correct offset, and VERY lightweight (aluminum), if you can find a used set in your area, or ebay.
Reactions: mrbb
I was told that the Maxxis Zillas are one of the lightest tires made.
Wayne
Reactions: wheelsquad
Im bored at work so i figured id do some searching for some of the most popular tires i have been seeing lately.
Maxxis M911Y(Front) & M912Y(Rear)*Very Very Similar To The OEM Tread
25X8-12 = 13.6lbs
25X10-12 = 17.5lbs
Maxxis Zilla
24X10-11 = 16.5lbs(Stock Size)
24X8-12 = 13.4lbs(Stock Size)
25X8-12 = 14.8lbs
25X10-12 = 17.90lbs
Mazzis MudZilla
25X8-12 = 23.7
25X10-12 = 28.1
ITP Mud Lite AT
25X8-12 = 15.5lbs
25X10-12 = 19.5lbs
Kenda Bear Claws
25X8-12 = 17.8lbs
25X10-12 = 23.0lbs
Kenda Executioner
25X8-12 = 20.4lbs
25X10-12 = 24.8lbs
Source = https://www.denniskirk.com/
Wayne
Reactions: SamUK
Yes, 8,9,10,11 & 12” wide are all available, some brands may vary but usually those widths are a common size. Personally I would stick to 8 or 9” on the front and use 10 to 12” on the rear.
Anything other than a 24-8-12 so I can use my rear rims? Like a 24-10-12?
Not sure what you are getting at with this question. Just spend some time on rmatvmc.com or motosport.com and you'll see the crazy amount of sizes available for 12" rims.
1 - 13 of 13 Posts
