If that brass plug you're seeing is on the side, the pilot screw is not under it. The pilot screw is on the bottom of the carburetor. From the service manual:On my 2009 OEM Honda Recon 250 carburetor, I'd like to adjust the air/fuel screw but it appears to be covered by an inset piece of concaved brass that I believe is called a Welch plug. How to I remove that?
picture didnt make it. try again.I just pulled the carb off my 2017 Honda Recon and found the same thing. Thanks @Sunset for sharing your experience. I'll get that plug off.
Sorry,, i aint seeing right. nothing new.. the pictures to me dont look like a screwdriver slot. more like a water shut off valve. from the main.. special tool thing..I also wanted to adjust my Recon’s carburetor and I had the same brass plug not letting me. I think it’s for emissions, they don’t want you to adjust it. I ended up taking my Dremel and cutting off some of the steel round piece that hangs down and covers the plug. Then I cut a slot on the plug put my screwdriver in there and unscrew it. It worked great. Just be careful when cutting.
