I have a 2007 Honda rancher 420 fuel injected. It will crank and crank and back fire out if exhaust. It has a yellow/orange spark. It is getting fuel. Could the spark be bad cdi? How could I test it? Thanks in advance!
if it was valves ?, then the compression would be to low to fire/ignite, and run ?, but if the timing is off ?, then this would force the ignited fuel out the intake valve, very posb the intake valve is not right ?, soo..maybe we are both on to something hereWhen timing is off for what ever reason it can be advanced or retarded, your getting fuel pumped into the exhaust and then it's getting ignited. The Valves may be to tight or just out off time. Check them and take them off the possibility list, It's free to look before buying more parts you don't need.
agreed !..lol.When you do trouble shooting it's not what you assume is wrong it's the possibilities you eliminate. Checking to be sure is free!
Even the worlds best agree with this principal,...... but in different words.When you do trouble shooting it's not what you assume is wrong it's the possibilities you eliminate. Checking to be sure is free!
