You need something like this: https://www.amazon.com/MATCC-Adjust...F8&qid=1520383897&sr=8-3&keywords=foam+cannonI always wash mine at a car wash with stuff called super soap. It makes it shine like brandnew. Cant beat pressure wash with soap added right to it. I havent been able to figure out how to add the soap directly to my pressure washer. And for some odd reason nothing works as good.
Wow that is exactly what i need lol! Thanks!Nothing beats a foam cannon, I use chemical guys soap
Great tips on cleaning, but you can also do a few things on the front end to make cleaning easier. That is, you can spray the underneath (not the engine or muffler) with Baby Oil. Baby Oil will put a light film on surfaces reducing adhesion of mud to components, a trick used in many dirt track cars.... More expensive, but equally as effective is SC1 and sure you could google to find other options.Get my new quad Friday What is best long term to wash it with ? Simple green, purple power? Or like a foam cannon Keeping in mind whats going to be best on it long term !
You can add a soap injector to most units, downstream injectors put soap in the line before the pump, and there are also high pressure injectors that can be installed where the hp hose connects to the outlet. Both should be under 20 bucks.I always wash mine at a car wash with stuff called super soap. It makes it shine like brandnew. Cant beat pressure wash with soap added right to it. I havent been able to figure out how to add the soap directly to my pressure washer. And for some odd reason nothing works as good.
10-4 ordered what bryan put a link to lastnight. Thanks guys! For some reason i must have been typing my description wrong. Cuz i couldnt find that anywhere.You can add a soap injector to most units, downstream injectors put soap in the line before the pump, and there are also high pressure injectors that can be installed where the hp hose connects to the outlet. Both should be under 20 bucks.I always wash mine at a car wash with stuff called super soap. It makes it shine like brandnew. Cant beat pressure wash with soap added right to it. I havent been able to figure out how to add the soap directly to my pressure washer. And for some odd reason nothing works as good.
Get my new quad friday
