1 - 15 of 15 Posts
why do you need two ?, you plan on breaking one from the get go ?..lol.
Shade , how is your buddy doing , I talked with him for an hour one time , down to earth and very knowledgeable , super nice guy , told me bring a trailer and a fist full of dollars and I could load up on 300's
I am going to take a stab at this , but 350's are not my main stay , I " think " the 25t gear was used on early models and for just one year or so , and the later models were 41t gears ----so what year is he actually looking for
I think he's after parts for a 1986 ?. most old 350's used 25t gears.
sorry doing way to many double shifts real short at work but the reason for 2 is I have 2 86 trx350s I have a 25t but its broke in half bought two off ebay and 1 is way too thick the other is just a little bit too thick so a waste of 100 bucks there and the machine shop says they wont turn them down for me, Its my fault I typed in 25t gear for Honda and some came up for different years so I thought that's just what I needed not thinking there could be different thickness,
reading up on these I guess they made this gear for different years and some 3 wheelers that are the same, all this is because I like to own old school things nows heres the kicker 1 350 is mine the 2nd one was my parts machine my son came home for a visit he lives a couple hours away and works a lot but he checks out what I have done to my trx in the past couple months and says heres a grand see where you can get with that and build me one from your parts quad
I know what you mean about e-bay , when you do a search it will give you a few parts with the same number you punched in and then fill the space with parts that are close , I always read the fine print of the description before pulling the trigger ------ I don't have any 350's in my fleet , but have parted a few out and read many threads on 350's , seems you are looking for a very rare piece -------------- how much would have to come off the one that you have that is thicker , maybe grind off a little at a time with a grind , I say a little at a time so you do heat it up too bad and lose the temper , seems they should be able to mill it , but they might be afraid of breaking cutting tools on it
I may have one at the shop. Ill check for you.
Honda parts nation should have it.
Discussion Starter · #14 ·
yes its the right number but I may have found out something else there is a kit on ebay that says its an updated gear set for this machine the gears are different numbers so all the parts that I have laying around I may have something that might work this kit says it has a 22t instead of the 25t and the double gear is a 15 by 43 the one I have is I believe is 18 by 43.The bad part is that there is just what I need on ebay now for 100 but with the holidays coming up I really don't have the cash right now for it,I guess for right now I can still just kick start it
Discussion Starter · #15 ·
I got it working I think this will work, one of the thicker ones I have I put it on the bike but with the cover tightened down it binds so I made a thicker gasket for the cover and it seems to work, no leaks turns over real nice, so I guess time will tell I am planning on checking it in a week or so to see if anything is wearing wrong but for now it has electric start
1 - 15 of 15 Posts
