You're welcome.Thank you very much for this info!
the reason your valves click when you first start your atv is...when your valves are cold..they do this..when you get them hot after a few min's..they expand...making them higher..which..closes the valve clearance gap between the rocker arm and the top of the valve spring...there is a time frame in your owners manual that should tell you when to check and adjust them...if you don't have a manual..then do what i do...go by sound. if it's '' ticking''..and keeps ticking even after it's fully warmed up..then your valves need adjusting....or your timming chain is streched causing it to slap against the timming chain guides.What symptoms present themselves that lead one to look into valve adjustment? My old 94 trx300fw sometimes makes a clicking noise while idling after start up on right side. sometimes sound goes away sometimes not. Could that be valves? How often should valves be adjusted? I have never ventured into valve adjusting and wondered if it might be in order for this old machine.
Thanks.
all you need is a 10mm wrench..and a screw driver, and a set of feeler gauges.Thanks shadetree and Helmut. Where do I get the valve wrench that is mentioned in Clymer manual to do the adjustment? Any Automotove store or is it a Honda tool?
