Hi there I've Rebuild a 2001 Honda foreman 450 and when i Adjust the valves it seems to just undo what i've done could it be that the timing is off on the motor ? Need help
when you say you rebuilt the engine, what made you do this ?. did you not put a new cam chain in ?, was the top end checked for bent/broken valves ?. there is a sticky in the repair section that explains how to set and adjust valves.
Discussion Starter #3
Well i bought the Quad of a friend and the motor was in terrible shape, so i had to changed some stuff on the motor but no i haven't changed the cam chain
you can find faster, more help here ---> www.atvhonda.com
