Been wanting to clean up a 1984 Atc200x. Was wondering if gunk engine degreaser would be safe to use on the motor, or would it ruin gaskets, rubber, etc. Thanks.
yes that will work.. will not hurt the engine just be careful if you use a power washer that can damage seals and out water where you do not want it..
if your trying to remove the mud stains and what not off the motor ?..your better off with some small wire brushes, and some easy-off over cleaner !. also..super clean from wally world works very well !..just don't let parts sit with it on them long ?, and wear gloves...it burns if left on your hands long !.lol.
Spray engine degreasers are the best in my opinion because they are easy to use and easy to clean . They are less concentrated and does not harm the engine. Currently I am using Rx spray degreaser and it is working best for me
RX Marine was established in 1996 in Mumbai, India; as chemical manufacturing company catering exclusively to the needs of the marine industry. In a short span of 12 years the company has established itself as one of the leading wholesale suppliers of a wide range of chemicals for - Marine industry internationally - and other local industires and plants. Our client list bears testimony to this. The RXSOL policy has its foundations on two pillars of strength - a continuous investment in research and development to deliver premium quality products and a commitment to service.
Degreaser
I use kerosene to clean oring chains and my engine. Sure has an odor but doesn't ruin seals and you can always dilute it with a few parts water or even add a little soap.
