I'll tighten the chain and see what that does to the equation ?
you can't tighten the cam chain bro !, it has an automatic cam chain tensioner built into the back side of the engine case. you have to remove the back engine cases in order to change the cam chain, which means, the starter has to come off, pull starter removed, stator case removed, flywheel removed, then you can replace the cam chain. you will need to drop the rear swing arm in order to get the rear engine case off. and you will need a flywheel puller tool to pop the flywheel off.
Ahh rightio, saw something about the chain tensioner in the manual obviously it's not adjustable, excuse my lack of mechanical knowledge this is my first proper ATV project
