I have a 2007 Honda Rancher 420 efi manual shift. I had to replace ALL of the fuel system because it sat for years without being started. Before and after getting it to run properly I have a problem with the turn signals and only the turn signals.
Whenever I turn the turn signals on in either direction, it kills the engine? Other lights work properly. I doubt I absolutely need them to work, but if I were to sell it I would want them to.
While it was sitting I had a mouse/rat chew up a lot of the wiring in the back area where the fuses/relays are. I reconnected all the chewed up wiring and double then triple checked it and is seems to be correctly hooked up. Everything else works correctly.
Could it be a relay or fuse? The battery was hooked up when the rat got to it and was discharged when I fixed the wiring. I replaced the battery.
Any idea? I know little about how it's designed.
Thanks in advance, Dale
