Hi all,
New to this so here goes, i have a 2012 TRX680FA Fourtrax Rincon, i bought it a couple of years ago and it is in decent condition. I am having trouble with the motor cutting out mainly when the engine is hot. It will start back up but as i try to add throttle will cut out on me and so i start the process again, eventually it will engage again and i will get it back to my shop. i read where it was possibly the fuel filter when hot. So i have changed Oil, Oil Filter, air Filter and fuel filter but it is still the same, i assumed i would be able to adjust the idle speed and maybe this would fix it but i do not see where i can do that on this model, all help suggestions appreciated thanks.
If more info is required please reach out thanks.
Not the same machine, but my trx300 4x4 was cutting out on me, and it was stumbling under acceleration. I went through the fuel system, but it turned out to be a hairline crack in the porcelain on the spark plug. The plug looked real good, but replacing it is what made the difference. It may not be your problem, but it's a cheap diagnostic step to replace it with a new one (make sure it's gaped properly).
