I have a 1999 Honda TRX450ES that only starts and idles when you let off the start button. If you pull the plug out and crank it it only sparks when you let off the starter. When running if you give it gas it dies. I have replaced the pulse generator, CDI box and checked battery voltage and connections. Has anybody else had a similar problem and what is next to check or do? Thanks in advance for any help.
