So the only issue is your choke knob won't stay out when you pull it?I looked at carb end and sheathing is not attached. Ordered replacement cable with knob. Any advice? I can grab wire and pull out about an inch at carb but it goes right back in. 2006 model es
yep, choke is there, minus the choke cable. front/forward plastic nut, 14mm, this is your choke valve.I have new carb and it seems to have a lot of parts and hoses. Here's pics from all 4 sides. KEIHIN VE94E. Can you tell if it has starter valve?
yep, slide the strainer over the brass tube, then install up into/or down..depending on how your tank is laying/sitting ?. then bolt it to the tank. make sure you got the old strainer out of the tank, they sometimes stay in there when you pull the petcock.The white hard plastic part shown on pic was missing when I removed fuel valve. Is it a strainer. Does it go over the brass tube inside the tank?
hate to break it to ya ?..but this pic you got here of that carb ?..its not an oem honda carb !.Great !
Look in manual for carb number or click parts links
Keihin
VE94E?
Look on side of carb, forward of fuel inlet.
