Hello All,
I had to rebuild my carb on one of my 1987 TRX350d's and when I did so, the Starter Jet screw totally stripped. Unfortunately, I had to drill it out since Easy-Out's didn't work. Now when I did this, it went all the way through and I felt my drill bit hit the inside wall on the other side (you can look through the top jet tubes and see it make contact, but I didn't obviously drill any further).
Now I don't believe this has anything to do with what is happening,but it's food for thought. Anyways, once I drilled it out, the rest of the screw collapsed inward and the threads remained intact without needing to be re-tapped.
So I rebuild the carb, machine starts right up - however it runs high on idle. Now, the previous owner had the pilot screw backed out 2 3/4 turns which I returned it to and I believe that to be the problem. I backed it down to 2 turns but it doesn't seem to be helping. Throttle is all the way to minimum.
Oddly the Oil Temp Light goes on and off too as this thing idles high ... I don't remember it idling this high before I did the rebuild, but then again it ran terrible before.
Any ideas?
Any ideas?
