There is no blockage between the left & right side in the TRX350 swingarms. Once you remove either the left or right side bearing race and cap you can use a long rod (that china made breaker bar that a well-intentioned relative got ya for christmas works perfect here
) and a big hammer to drive out the opposite side race and cap. If its rusted real bad use a torch and heat it up cherry red before driving them out. You can clean the swingarm up and repaint it while you are waiting on replacement bearings.
I think I have a swingarm here somewhere in my stash if you need one of those... if so, its yours for the shipping cost to your place. I have some old bearings too, but I'm sure those are worn out or I would have put them to work in something by now..? I'll see if I can find them just in case...
You can fix that swingarm boot with some 3M Super-fast Urethane Windshield sealer (part # 08609 in the big tube, you can buy it in smaller quantities too, I think). I use that stuff for a lot of rubber repairs and to improve the strength/life of some parts. Just prep the rubber boot good using a small wire brush and Lacquer thinner, then skim coat it with the 3M using one of your fingers. Allow it to cure for 48 hours and run it... easy fix.
