before you swapped pick up coils...was it at anytime firing then ?. any chance you may have pinched any of the wires at the back when you did this work ?. you really need to take a step back, and think of when all this started ?, what were you doing when it just died ?. when it did die, did you check from spark plug spark then ?. was it shut off anytime with the kill switch ?, was/has the ignition switch been checked for power going in, and coming out ?. most important question i have is...WHY DID THE NEUTRAL LIGHT GO OUT ?, AND WHAT DID YOU DO TO MAKE IT COME BACK ON ?. have you checked the diode in the fuse block ?.
this is useless too me, why ?, because all it shows me what i already know, the spark plug is connecting the coil to the engine as ground for spark...this does not ground the coil to the frame !. and have you checked all your harness grounds to frame ??.
well..i am sure i asked you a couple times to pull the switch housing apart, and check the switch wires...did i not ???, but anyway..thank you for the update !. as i said...the simple stuff always bites us hard when we over look it !.
21 - 38 of 38 Posts
