I have a 2001 rancher trx350 and I have no power to my key, when I turn it, it does absolutely nothing. No headlights, oil temp, or neutral light. Went riding 2 days before it did this and it never had an issue. Any ideas would be a big help
I'd check the basics, blown fuses, Loose battery terminals, bad grounds, and check your ignition switch. It could've gone bad. But, given you've rode it 2 days before i'm guessing it's a loose battery cable or one of your ground cables are loose. Just guessing!
v
v
It has power to the switch and the switch is good according to the ohms meter, and I think the grounds are good because I can just the solenoid and it turns over. It turns over but doesn’t spark because it thinks the key is not in. Any specific grounds I should check?
I can recommend you download the service manual and check parts links in my signature block below.
Here’s a pic of the schematic for an FM page 22-2
151405
