Ive changed everything the CDI , Ignition coil, Spark plug, Starter, Solenoid, fuse, carb is new, Battery is good, im getting compression, just no spark also my wiring is all jacked up, i dont have the handle bar controls, i replaced the key and have a on and off switch. i was thinking about gettin a wire harness but idk if thats the problem... I also noticed my reverse and neutral sensor wires going into the side cover were damaged... I need help... Ive watched just about every youtube video.... I even have the service manual... I still cant get my atv started....
