300 2wd , I got the swing arm off and cleaned up , when I took the bolt out which holds the diff to the swing arm water came out , so I checked the diff oil and no water in it , the pinion seal did it's job , good thing I got to it when I did , when I got the swing arm off I found that the bearing on one side totally failed and the balls got pushed thru the steel plate and that was how the water got into the swing arm's drive shaft tube , also the u-joint was hitting the bottom of the swing arm and dented it up ( you can see it in the pic ) , I was able to beat that back in shape the u-joint also sticks so it is bad , so I need a u-joint , swing arm bearings , seals and plates , a pinion seal while I am in there and a new to me used u-joint
