1 - 19 of 19 Posts
TRX: Try going to the Partzilla website, or Rocky Mountain ATV website as they show Honda Parts diagrams and part number. However, I don't know if they go back to 1995 though.
From your thread title, I'm wondering, Are you looking for a rectifier/regulator. (A diode is a rectifier). If you are looking for a rectifier/regulator, you can get one from a newer model as they all do about the same thing. But, do get a Honda part. Don't fall prey for some of the Chinese parts that are on Ebay.
I believer this is what I'm looking for as this looks to match up to the plug I've got
Text Font Photography Adaptation Stock photography
Basically I'm refitting a brand new wiring loom and have no parts from the origional
It's all fitted fine but obviously won't spark till I bridge this plug
and in the wiring diagram I have , it says it's a diode.
Welcome to the fourm I never seen a diode like that? I always thought the little piece of metal that links the ends of the fuse together when you replace a fuse.
That is definitely a large diode. :) As I suggested above, I'd look on Partzilla or Rocky Mtn ATV's websites, and you should be able to find that diode. If they don't have diagrams for a 1995 model, try a later TRX300 model as they should have the same diode.
I could tell you how to make it work with a diode from Radio Shack, but, I'd rather see you use the diode from Honda :)
Discussion Starter · #9 ·
It's a white/clear plug on the harness that it plugs into I'll see if I can find a pic
Oh and you've no idea how much I appreciate all the help chaps :)
Discussion Starter · #12 ·
Text Font Line Illustration
I've got it, it's number 12 in this picture if this helps anyone else 31700-124-008 is the part number.
Wonder why it's not fitted to a lot of models?
I couldn't even tell if it was on the origional loom as I don't have it
Many thanks to all that helped and yes genuine honda all the way!!!
Hi TRX90: That is the right Diode -- The Diode is in the solenoid circuit to prevent a positive feedback voltage into the CDI from the solenoid coil.
Reactions: jdp
Try Honda parts house .com they go all the way back into the 80s and they have all the diagrams I wouldn't buy it off of them cause they are really expensive but you can get the part number and look it up on another web site
anytime you need this part ?..it's always listed in with the wire harness :). well I looked just now ..and I did not see them listed anymore ?..hmmm..gonna keep looking...lol.
wiring schematics from old school bikes call it a clutch diode even though it has nothing to do with the clutch , later models call it a rectifier assembly. , silicon -----what I found wild is that same part number fits this short list of bikes , you may have trouble finding a used one as it looks rare , lol ----------
This Honda RECTIFIER, SILICON is used on these models and components:
1986 ATC250ES A
1986 ATC250SX A
1986 TRX250 A
1987 ATC250ES A
1987 ATC250SX A
1987 TRX250 A
1988 TRX300 A
1988 TRX300FW A
1989 TRX300 A
1990 TRX300 A
1990 TRX300FW A
1991 TRX300 A
1991 TRX300 AN
1991 TRX300FW A
1991 TRX300FW AN
1992 TRX300 A
1992 TRX300 AN
1992 TRX300FW A
1992 TRX300FW AN
1993 TRX300FW A
1993 TRX300FW AN
1994 TRX300 A
1994 TRX300 AN
1994 TRX300FW A
1994 TRX300FW AN
1995 TRX300 A
1995 TRX300 AN
1995 TRX300FW A
1995 TRX300FW AN
1995 TRX400FW A
1995 TRX400FW AN
1996 TRX300 A
1996 TRX300 AN
1996 TRX300FW A
1996 TRX300FW AN
1996 TRX400FW A
1996 TRX400FW AN
1997 TRX250 A
1997 TRX250 AC
1997 TRX300 A
1997 TRX300 AN
1997 TRX300FW A
1997 TRX300FW AN
1997 TRX400FW A
1997 TRX400FW AN
1998 TRX250 A
1998 TRX250 AC
1998 TRX300 A
1998 TRX300 AC
1998 TRX300FW A
1998 TRX300FW AC
1998 TRX400FW A
1998 TRX400FW AC
1999 TRX250 A
1999 TRX300 A
1999 TRX300 AC
1999 TRX300FW A
1999 TRX300FW AC
1999 TRX400EX A (99-04)
1999 TRX400FW A
2000 TRX250 A
2000 TRX300 A
2000 TRX300 AC
2000 TRX300FW A
2000 TRX300FW AC
2000 TRX400EX A (99-04)
2000 TRX400FW A
2001 TRX250 A
2001 TRX250EX A (01-05)
2001 TRX400EX A (99-04)
2001 TRX400FW A
2001 TRX500FA A (TRX500FA01-04-FGA04)
2002 TRX250EX A (01-05)
2002 TRX250TE A (TE)
2002 TRX250TM A (TM)
2002 TRX400EX A (99-04)
2002 TRX500FA A (TRX500FA01-04-FGA04)
2003 TRX250EX A (01-05)
2003 TRX250TE A (TE)
2003 TRX250TM A (TM)
2003 TRX400EX A (99-04)
2003 TRX500FA A (TRX500FA01-04-FGA04)
2004 TRX250EX A (01-05)
2004 TRX250TE A (TE)
2004 TRX250TM A (TM)
2004 TRX400EX A (99-04)
2004 TRX500FA A (TRX500FA01-04-FGA04)
2004 TRX500FGA A (TRX500FA01-04-FGA04)
2005 TRX250EX A (01-05)
2005 TRX250TE A (TE)
2005 TRX250TM A (TM)
2005 TRX400EX A (05-06)
2006 TRX250EX A (06-07)
2006 TRX250TE A (TRX250TE)
2006 TRX250TM A (TRX250TM)
2006 TRX400EX A (05-06)
2007 TRX250EX A (06-07)
2007 TRX250TE A (TRX250TE)
2007 TRX250TM A (TRX250TM)
2007 TRX400EX A
2008 TRX250EX A (08)
2008 TRX250TE A (TRX250TE)
2008 TRX250TM A (TRX250TM)
2008 TRX400EX A
2009 MUV700 2A
2009 TRX250TE A (TRX250TE)
2009 TRX250TM A (TRX250TM)
2009 TRX250X A
2009 TRX400X 3A
2009 TRX400X A
2011 TRX250TE A (TRX250TE)
2011 TRX250TM A (TRX250TM)
2011 TRX250X A
2012 MUV700 2A
2012 TRX250TE A (TRX250TE)
2012 TRX250TM A (TRX250TM)
2012 TRX250X A
2012 TRX400X A
2013 MUV700 2AC
2013 TRX250TE AC (TRX250TE)
2013 TRX250TM AC (TRX250TM)
2014 TRX250X AC
2014 TRX400X AC
CT70K3 A
CT70K3 A
CT70K3 A
CT70K3 A
CT70K3 A
1974 CT70K3 A
1975 CB750F A
1975 CT70K3 A
1976 CB550K A
1976 CB750F A
1976 CB750K A
1976 CT70 A
1976 CT70K3 A
1977 CB400F A
1977 CB550K A
1977 CB750F A
1977 CB750F A
1977 CB750K A
1977 CT70 A
1977 CT70K3 A
1977 XL75 A
1978 CB400TII A
1978 CB550K A
1978 CB750F A
1978 CB750F A
1978 CB750K A
1978 CT70 A
1978 CT70K3 A
1978 XL75 A
1979 CB400TII A
1979 CB650 A
1979 CB750F A
1979 CB750K A
1979 CB750L A
1979 CBX A
1979 CM400T A
1979 CT70 A
1979 CT70K3 A
1979 XL75 A
1980 C70 A
1980 CB400T A
1980 CB650 A
1980 CB650C A
1980 CB750C A
1980 CB750F A
1980 CB750K A
1980 CB900C A
1980 CBX A
1980 CM400E A
1980 CM400T A
1980 CT110 A
1980 CT70 A
1980 CT70K3 A
1980 GL1100 A
1980 GL1100I A
1981 C70 A
1981 CB400T A
1981 CB650 A
1981 CB650C A
1981 CB750C A
1981 CB750F A
1981 CB750K A
1981 CB900C A
1981 CB900F A
1981 CBX A
1981 CM400C A
1981 CM400E A
1981 CM400T A
1981 CT110 A
1981 CT70 A
1981 CT70K3 A
1981 GL1100 A
1981 GL1100I A
1981 GL500 A
1981 GL500I A
1981 XL80S A
1982 CB450SC A
1982 CB450T A
1982 CB650 A
1982 CB650SC A
1982 CB750C A
1982 CB750F A
1982 CB750K A
1982 CB750SC A
1982 CB900C A
1982 CB900F A
1982 CBX A
1982 CM250C A
1982 CM450C A
1982 CM450E A
1982 CT70 A
1982 CT70K3 A
1982 CX500TC A
1982 GL1100 A
1982 GL1100A A
1982 GL1100I A
1982 GL500 A
1982 GL500I A
1982 VF750C A
1982 VF750S A
1982 XL80S A
1983 CB1000C A
1983 CB1100F A
1983 CB450SC A
1983 CB550SC A
1983 CB650SC A
1983 CB750SC A
1983 CM250C A
1983 CM250C AC
1983 CM450E A
1983 CX650T A
1983 GL1100 A
1983 GL1100A A
1983 GL1100I A
1983 GL650 A
1983 GL650I A
1983 VF1100C A
1983 VF750C A
1983 VF750F A
1983 VF750S A
1983 VT500C A
1983 VT750C A
1983 XL80S A
1984 CB650SC A
1984 CB650SC AC
1984 CB700SC A
1984 CB700SC AC
1984 GL1200 A 1200-I
1984 GL1200 AC 1200-I
1984 GL1200A A 1200-I
1984 GL1200A AC 1200-I
1984 GL1200I A 1200-I
1984 GL1200I AC 1200-I
1984 VF1000F A
1984 VF1000F AC
1984 VF1100C A
1984 VF1100C AC
1984 VF1100S A
1984 VF1100S AC
1984 VF500C A
1984 VF500C AC
1984 VF500F A
1984 VF500F AC
1984 VF700C A
1984 VF700C AC
1984 VF700F A
1984 VF700F AC
1984 VF700S A
1984 VF700S AC
1984 VF750F A IL
1984 VF750F AC
1984 VT500C A
1984 VT500C AC
1984 VT700C A
1984 VT700C AC
1984 XL80S A
1985 CB450SC A
1985 CB450SC AC
1985 CB650SC A
1985 CB650SC AC
1985 CB700SC A
1985 CB700SC AC
1985 CMX250C A
1985 CMX250C AC
1985 GL1200A A 1200-I
1985 GL1200A AC 1200-I
1985 GL1200I A 1200-I
1985 GL1200I AC 1200-I
1985 GL1200L A 1200-I
1985 GL1200L A GL1200L
1985 GL1200L AC 1200-I
1985 GL1200L AC GL1200L
1985 VF1000R A
1985 VF1000R AC
1985 VF1100C A
1985 VF1100C AC
1985 VF1100S A
1985 VF1100S AC
1985 VF500C A
1985 VF500C AC
1985 VF500F A
1985 VF500F AC
1985 VF700C A
1985 VF700C AC
1985 VF700F A
1985 VF700F AC
1985 VF700S A
1985 VF700S AC
1985 VT1100C A
1985 VT1100C AC
1985 VT500C A
1985 VT500C AC
1985 VT700C A
1985 VT700C AC
1985 XL80S A
1985 XL80S AC
1986 CB450SC A
1986 CB450SC AC
1986 CB700SC A
1986 CB700SC AC
1986 CMX250C A
1986 CMX250C AC
1986 CMX250CD A
1986 CMX250CD AC
1986 CMX450C A
1986 CMX450C AC
1986 GL1200SEI A SE-I
1986 GL1200SEI AC SE-I
1986 VF1000R A
1986 VF1000R AC
1986 VF1100C A
1986 VF1100C AC
1986 VF500F A
1986 VF500F AC
1986 VF700C A
1986 VF700C AC
1986 VFR700F A
1986 VFR700F AC
1986 VFR700F2 A
1986 VFR700F2 AC
1986 VFR750F A
1986 VFR750F AC
1986 VT1100C A
1986 VT1100C AC
1986 VT500C A
1986 VT500C AC
1986 VT700C A
1986 VT700C AC
1987 CBR1000F A
1987 CBR1000F AC
1987 CBR600F A
1987 CBR600F AC
1987 CMX250C A W
1987 CMX250C AC
1987 CMX450C A
1987 CMX450C AC
1987 VF700C A
1987 VF700C AC
1987 VFR700F2 A
1987 VFR700F2 AC
1987 VT1100C A
1987 VT1100C AC
1987 VT700C A
1987 VT700C AC
1988 CBR1000F A
1988 CBR1000F AC
1988 CBR600F A
1988 CBR600F AC
1988 GL1500 A
1988 GL1500 AC
1988 NT650 A
1988 NT650 AC
1988 NX125 A
1988 NX125 AC
1988 VF750C A
1988 VF750C AC
1988 VT1100C A
1988 VT1100C AC
1988 VT600C A
1988 VT600C AC
1988 VT800C A
1988 VT800C AC
1988 VTR250 A
1988 VTR250 AC
1989 CB400F A
1989 CB400F AC
1989 CBR600F A
1989 CBR600F AC
1989 GL1500 A
1989 GL1500 AC
1989 NT650 A
1989 NT650 AC
1989 NX125 A
1989 NX125 AC
1989 PC800 A
1989 PC800 AC
1989 VT1100C A
1989 VT1100C AC
1989 VT600C A
1989 VT600C AC
1989 VTR250 A
1989 VTR250 AC
1989 XL600V A
1989 XL600V AC
1990 CB400F A
1990 CB400F AC
1990 CBR600F A
1990 CBR600F AC
1990 NT650 A
1990 NT650 AC
1990 NX125 A
1990 NX125 AC
1990 VFR750R A
1990 VFR750R AC
1990 VT1100C A
1990 VT1100C AC
1990 VTR250 A
1990 VTR250 AC
1990 XL600V A
1990 XL600V AC
1991 CB250 A
1991 CB250 AC
1991 CT70K3 A
1991 GL1500I A
1991 GL1500I AC
1991 GL1500SE A
1991 NT650 AC
1992 CB250 A
1992 CB250 AC
1992 CT70K3 A
1992 GL1500I A
1992 GL1500I AC
1992 VT1100C AC
1993 CB250 A
1993 CB250 AC
1993 CT70K3 A
1993 GL1500I A
1993 GL1500I AC
1993 VT1100C AC
1993 XR650L A
1993 XR650L AC
1994 CB250 A
1994 CB250 AC
1994 CT70K3 A
1994 GL1500I A GL1500I
1994 GL1500I AC GL1500I
1994 VT1100C A
1994 VT1100C AC
1994 XR650L A
1994 XR650L AC
1995 CB250 A
1995 CB250 AC
1995 GL1500I A GL1500I
1995 GL1500I AC GL1500I
1995 VT1100C A VT1100C
1995 VT1100C AC VT1100C
1995 VT1100C2 A VT1100C2
1995 VT1100C2 AC VT1100C2
1995 XR650L A
1995 XR650L AC
1996 CB250 A
1996 CB250 AC
1996 CMX250C A
1996 CMX250C AC
1996 GL1500I A I
1996 GL1500I AC I
1996 VT1100C A VT1100C
1996 VT1100C AC VT1100C
1996 VT1100C2 A VT1100C2
1996 VT1100C2 AC VT1100C2
1996 XR650L A
1996 XR650L AC
1997 CB250 A
1997 CB250 AC
1997 CMX250C A
1997 CMX250C AC
1997 XR650L A
1997 XR650L AC
1998 XR650L A
1998 XR650L AC
1999 CB250 A
1999 CB250 AC
1999 CMX250C A
1999 CMX250C AC
1999 CMX250C2 A
1999 CMX250C2 AC
1999 GL1500CF A
1999 GL1500CF AC
1999 XR650L A
1999 XR650L AC
2000 CB250 A
2000 CB250 AC
2000 CMX250C A
2000 CMX250C AC
2000 CMX250C2 A
2000 CMX250C2 AC
2000 GL1500CF A
2000 GL1500CF AC
2000 XR650L A
2000 XR650L AC
2001 CB250 A
2001 CB250 AC
2001 CMX250C A
2001 CMX250C AC
2001 GL1500CF A
2001 GL1500CF AC
2001 XR650L A
2001 XR650L AC
2002 CB250 A
2002 CB250 AC
2002 CMX250C A
2002 CMX250C AC
2002 XR650L A
2002 XR650L AC
2003 CB250 A
2003 CB250 AC
2003 CMX250C A
2003 CMX250C AC
2003 XR650L A
2003 XR650L AC
2004 CB250 A
2004 CB250 AC
2004 CMX250C A
2004 CMX250C AC
2004 NRX1800DA A
2004 NRX1800DA AC
2004 NRX1800DB A
2004 NRX1800DB AC
2004 NRX1800EA A
2004 NRX1800EA AC
2004 NRX1800EB A
2004 NRX1800EB AC
2004 XR650L A
2004 XR650L A-A
2004 XR650L A-B
2004 XR650L A/A
2004 XR650L A/B
2004 XR650L AC
2004 XR650L AC-A
2004 XR650L AC-B
2004 XR650L AC/A
2004 XR650L AC/B
2005 CB250 A
2005 CB250 AC
2005 CMX250C A
2005 CMX250C AC
2005 NRX1800DA A
2005 NRX1800DA AC
2005 NRX1800DB A
2005 NRX1800DB AC
2005 NRX1800EA A
2005 NRX1800EA AC
2005 NRX1800EB A
2005 NRX1800EB AC
2005 XR650L A
2005 XR650L A-A
2005 XR650L A/A
2005 XR650L AC
2005 XR650L AC-A
2005 XR650L AC/A
2006 CB250 A
2006 CB250 AC
2006 CMX250C A
2006 CMX250C AC
2006 XR650L A
2006 XR650L AC
2007 CB250 A
2007 CB250 AC
2007 CMX250C A
2007 CMX250C AC
2007 XR650L A
2007 XR650L AC
2008 CB250 A
2008 CB250 AC
2008 CMX250C A
2008 CMX250C AC
2008 XR650L A
2008 XR650L AC
2009 CMX250C A
2009 CMX250C AC
2009 XR650L A
2009 XR650L AC
2012 CMX250C A
2012 CMX250C AC
2012 XR650L A
2012 XR650L AC
2014 CMX250C A
2014 XR650L A
1984 CH125 A
1984 CH125 AC
1984 NH125 A
1 - 19 of 19 Posts
