I ordered a used front shock for 92TRX250X it came without the bottom collar to put the bolt through to mount to A arm, so I ordered an OEM replacement, it fits in the hole on the shock but not tightly, it will still swivel. My question is, is this normal??? is this ok???? do I need to find a larger collar or bushing to fit tight in there??? is it possible this is a shock off a 300X and its just a slightly larger hole so if I order a collar off a 300X it will fit tight?? and if thats true do I need to order the other shock or are they the same length????
The holes that the bolt goes through on the shocks... correct? Yes they swivel.
yup, the collar fits in the housing of the shock and the bolt goes through the collar. it does fit in the shock but I didnt have to heat it up or pound it in tight or anything. I was just making sure as the top (spring side) doesnt seem to move at all. thanks
one is old and one is new. I just did a shock swap on my rhino. One of the fronts was like that. The top one didn't move but the bottom did.
Sweet, thanks alot!!!!
