Hi,
Pulled front cover off trx250 to do chains and all this fell out anybody know how it goes back?
welcome to the forums. yep, I know how every part goes back in. please down load the service manual, so YOU will know how it goes back in ???!!. In the mean time, the bearing cage fits inside the square metal plate that has 4 bolts and springs , this is your change clutch, next goes the bearing inside the bearing holder in the center, MAKE SURE YOU READ THE WORDS '' THIS SIDE OUT '' ?, if must face outwards from the clutch. next goes the bearing inside the bearing holder, next, install the round metal part, that has the fork attached to it, round part installs inside the bearing with the forks facing out, and down, now grease the outside of the forked area that has 3 indents for the 3 balls that have the spring, place the part with 3 balls and the spring, inside the fork area with the indents, with the spring facing inwards, now your change clutch arm that has the small well goes in, and under the fork area, be careful not to knock these parts off when installing the cover back on ?, and make sure you tighten down the cover bolts in a criss cross pattern SLOWLY !!. that's all there is to it.
