I have the service manual for this, and I believe I am correct, but I want to verify some stuff.
I have oil leaks at both of these pieces. I have new gaskets, which are just rubber O-ring types, which is wierd because I didn't know these were prone to leaking. Anyway, someone mentioned a while back that I needed to do something with the motor in order to get the valves in the right position to take these two pieces off or it would be bad. I do not believe that is true, and there is no reference in the service manual to orienting anything inside the motor before removing the bolts and pulling those parts off. Can anyone confirm that I need not do anything more than removing bolts and pulling the top two items off the motor? The cylinder head is held in place with nuts/studs internally, so there should be no issue there. I need to replace the two gaskets and the valve adjuster o-rings...should be pretty straightforward right?
